How to set a subtask assignee from a custom people field?
Theo Furrow
July 25, 2022
We use subtasks to track actions for multiple users in one issue. In this case, we have Business Analysts (BA) and Developers include on the issues as custom People fields. I am trying to use Automation to set the assignee of subtasks to either the BA or the Developer.
I have been able to get select the specific subtask of those we list to have a person assigned, but I am not having success at setting the assignee based on the person entered in to the BA people filed on the parent issue.
In the audit log I am getting this message:  Error editing issues:  BIZ-7474 (Specify a valid value for assignee (assignee))
Can someone advise on the verbiage I need to be using to get the ID from the BA people field to be set as the assignee for the subtask?
July 25, 2022
Hi @Theo Furrow
Based on your rule structure, I recommend referencing the trigger issue as the source for the parent.  Perhaps with this:
{{triggerIssue.customfield_10052.accountId}}
Please note you could also type in/paste that field for the assign field, without the need for the JSON edit.  To do so, just type/paste the smart value and it will appear below the field in Issue Edit, then you may select it for use.
Theo Furrow
July 27, 2022
Thank you very much. That worked great.
Like Bill Sheboy likes this
