  • Community
  • Q&A
  • Jira
  • Questions
  • How to set a workflow condition for groups as well as roles in jira , (FYI both are different proje
kudukuntla.shekar July 22, 2020
How to set a workflow condition for groups as well as roles in jira , (FYI both are different projects but workflow is same ) .
One project using roles and another project using group permission scheme.
Oliver Siebenmarck _Polymetis Apps_
This can be done using Jira Expressions, but you will need an app that supports custom workflow conditions with Jira Expressions. In my biased opinion Cloud Workflows is a great option, but there are other apps available as well.
Once you got your app-of-choice installed, just add a workflow condition that allows Jira Expressions. Let's say you want to check that a user either is in role 'Developer' in project PRJA or in role 'Admin' in project PRJB or is in the global group 'jira-administrators'. You would use an expression like this:
(user.getProjectRoles(new Project('PRJA')).filter(r => r.name == 'Developer').length > 0)
(user.getProjectRoles(new Project('PRJB')).filter(r => r.name == 'Admin').length > 0)
user.groups.includes("jira-administrators")
Depending on your exact use-case, you might need to experiment a bit, so here's the Jira Expressions reference documentation and the introduction guide.
Hope that helps,
  Oliver
Full disclosure: I work for Jodocus, the Vendor who created Cloud Workflows. Let me know if you need any help getting started.
