×Hi all,
I could close an EPIC when all tasks under that EPIC are completed.
Today, I received a query from my team to close an epic when half of the tasks under the epic are done while the rest (which would be negligible if half of them are completed) are not.
Is there any way I could set Automation for Jira to do that?
In my opinion...
It is counter-intuitive and contrary to best practices to close an Epic that has not-closed child issues. I think you should push back on that request. If the child issues don't need to be completed for the Epic to be considered complete, then why are they in the Epic? If the Epic can be considered complete without that work being completed, then those incomplete items should be moved out of the Epic.
Hi @Cindy Chan
Yes, and...to Trudy's thoughts:
This could be automated, however the only time I have seen a use case like this was when the business problem/need for the Epic was considered "solved" when part of the work was completed. (i.e. 80/20 rule, or Pareto Principle) For such a scenario I would expect the requestor of the Epic to make that call, and not based upon a number of completed issues.
Would you please clarify how you are using Epics (and their child issues), as that may help the community to offer ideas? Thanks!
Hi Trudy and Bill,
Thanks for your opinion. I get you that they are pretty counter-intuitive if it were to be software tracking process.
At the moment, we're using Jira to track biological experiments - certain plant traits after tissue culture.
In each group of plants, some would be positive for the trait we're looking for while some don't. And so, as long as we reach the target number of independent plants with the traits we're looking for, e.g. at least 20 plants, then we could move forward to phenotype them - thus considered the EPIC closed. We have various projects going on at the same time in the facility, each for a different set of traits. We need to track each plant since they are considered independent line and we have to do genotyping of each plant so each plant is an issue under the epic.
Best wishes, Cindy
Thanks, Cindy! I had not thought of such a use case before: the number of child issues in a particular status correlates to the progress of the parent epic.
You can probably modify/copy your existing rule to do what you ask:
