How to set field must be filled when workflow is transferring to next phase
何梦 July 4, 2023
For example,i transfer a issue from TODO to Holding through workflow,the deadline must be filled.
Trudy Claspill
Hello @何梦
Are you working with a Team Managed project or a Company Managed project? That information will show at the bottom of the panel on the left.
For a Company Managed project you would add a Field Required Validator to the workflow transition. Refer to
https://support.atlassian.com/jira-cloud-administration/docs/configure-advanced-issue-workflows/
For a Team Managed project you would add a Rule to the workflow transition. Refer to:
https://support.atlassian.com/jira-software-cloud/docs/available-workflow-rules-in-team-managed-projects/#Availableworkflowrulesinnextgenprojects-Restricttowhenanissueisaspecificvalue
In either case not all fields may be supported by the rule.
