How to set selectable values in a selection custom field via jira automation?
Patrick Roos
Hi there
How can I set selectable values in a selection custom field via automation?
My scenario:
I want to set selectable values in a "selection custom field" via automation. The selectable values come from an incoming webhook.
Is this possible? Which action should I select? Edit Issue or Edit Entity Properties?
Thanks for your help.
Regards, Patrick
October 30, 2020 edited
Hi @Patrick Roos
Did you figure this out already?
If not, you would want to use the issue edit action, and you can see information about accessing the webhook incoming data on this documentation page:
https://support.atlassian.com/jira-software-cloud/docs/smart-values-general/
Best regards,
Patrick Roos
Hi @Bill Sheboy
Thanks for your message!
Unfortunately I didn't figure it out already.
Yes, I know the smart values. But how do you can set selectable values in a selection custom field with smart values?
Thanks.
Patrick
November 4, 2020
Hi Patrick,
For custom fields, I believe you would need to use JSON to edit multiple value fields.  Please take a look at this page and search on "multiple" to see the examples:
https://support.atlassian.com/jira-software-cloud/docs/advanced-field-editing-json/
__Bill
