How to set short prefix in front of summary field ?
Jouni Riimala
Via automation I can set prefix in front of summary, for example when creating user requirement type of issue I'm getting User Requirement  - <tittle> issue as a result. For this I'm using {{issue.issuetype.name}} - {{issue.summary}} as a jql.
Target of mine would be to use shorter term for user requirement ex. UR - <title>, is this possible with jql ?
-Jouni
Hana Kučerová
May 17, 2022
Hi @Jouni Riimala ,
in general you should be able to do it, but with the usage of conditions in automation rule.
Something like:
If: Issue Type equals User Requirement
Then: Edit issue fields: Summary = UR - {{issue.summary}}
Else-If: Issue Type equals Story
Then: Edit issue fields: Summary = ST - {{issue.summary}}
Jouni Riimala
Thx, make sense. Need to experiment with this.
