I hope this message finds you well.
Regarding components in Jira Software, in my project company-manged, i have a lot of components, each with his own component lead.
I know that i can set the default assignee to the component lead, but i want onlt for a specific issue type, for example only for bugs.
When a bug is created the assignee will be the component lead.
Please advise!
Thank you!
Best regards,
David.
@David Pleşu
I am not sure your experience level, but you can get these via API
The Jira Cloud platform REST API (atlassian.com)
then you can place the value into the assignee field if the issue type is bug... : )..
Hi @David Pleşu ,
Welcome to atlassian community!
When you creating the issue type Bug, please add the components which component leads need to assign the issue for bug.
Components name | Components Lead |
Developer | Akash |
Tester | Tom |
Script | Jaz |
Suppose, If you are adding the Developer component in the Bug issue at the time of creating the issue, then After creating issue will directly assign to Akash. because Akash is the component lead of Developer component.
Assign issue hierarchy level
If you need more clarification, Please let me know.
Sanjen Bariki
Hi Sanjen,
Thank you for your answer,
But i have another issues types that also have component field in the screen, and here also the assignee will be the component lead, i want only for bugs.
David.
I tried with Automation, but i can't find the smart value for component lead.
And a json i can't create also.
BR,
David.
