How to set the value of fix version default field in an issue through groovy script?
Shagufta Gurmukhdas November 23, 2016
I have added a custom field for target version and when i create the issue, I can see the target version as the correct release version but the Fix Version built in one is set as None. What should I write in my script to make that the same as the value in my custom field? I have the version object as well as the version name string, but what exactly should be the line of code to set the fix version as that object ?
Vasiliy Zverev
November 24, 2016
Dear @Shagufta Gurmukhdas, if you hava version object then to set this only version you can use this
issue.setFixVersions(Arrays.asList(version))
Note, that all other version will be deleted.
Shagufta Gurmukhdas November 24, 2016
Worked, thanks a lot! @Vasiliy Zverev btw i am able to write this on the create postfunction, for the subtasks created for the issue currently being created. But for this parent issue, writing this same code doesnt work. Nor does anything else, like setting the summary etc. (in the create postfunction of issue being created) How to set the fields of the current issue?
Vasiliy Zverev
November 24, 2016
On create transition it is requred:
  1. Place post-function after postfunciton to create original issue
  2. Add code to store changes
    ComponentAccessor.getIssueManager().updateIssue(
            ComponentAccessor.getJiraAuthenticationContext().getUser()
            , issue
            , UpdateIssueRequest.builder().eventDispatchOption(EventDispatchOption.ISSUE_UPDATED).sendMail(false).build()
Here issue is the original issue? or the one with updated fields?
Vasiliy Zverev
November 24, 2016
Yes, I did that, but somehow this current issue still doesnt get updated..
Vasiliy Zverev
November 24, 2016
Could you provide full code for this post-fucntion?
Shagufta Gurmukhdas November 27, 2016
This is related to my other question..I want to update the current issue's version
import com.atlassian.jira.project.version.Version
import com.atlassian.jira.project.version.VersionManager
import com.atlassian.jira.project.Project
VersionManager versionManager = ComponentAccessor.versionManager
CustomField versionCF = customFieldManager.getCustomFieldObjectByName("Version/Release")
String valueOfversionType = issue.getCustomFieldValue(versionCF)
String versionstring=valueOfversionType.substring(1,valueOfversionType.size()-1)
Version versionn = versionManager.getVersion(issue.getProjectId(), versionstring)
issue.setFixVersions(Arrays.asList(versionn))
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
ComponentAccessor.getIssueManager().updateIssue(user, issue, com.atlassian.jira.event.type.EventDispatchOption.DO_NOT_DISPATCH, false)
@Vasiliy Zverev
Whether I do this for the version or any other field like summary, description etc, it doesn't update the current issue's field. (The one for which the post function is being written)
@Vasiliy Zverev Even a simple statement like this doesnt work for the current issue
issue.description = "abc"
I could simply put it in a post function for updating field( the default inbuilt postfunction) but i need to make this conditional, i.e dependent on some other field, hence I want to do it manually, but this isnt working sad (I am on the cloud instance)
Oh! I got the answer! laugh The postfunction is supposed to be put before that of the issue actually being created. laugh laugh laugh laugh
Jon Mort _Adaptavist_
November 28, 2016
All of the coded posted above will not work on Cloud as the API is totally different. The order of post functions in the cloud is not guaranteed as they are processed asynchronously.
4 votes
November 28, 2016
Hi Shagufta,
The following code will set the fix version in ScriptRunner for JIRA Cloud for the issue with key SAMPLE-1
def issueKey = 'SAMPLE-1'
def result = put('/rest/api/2/issue/' + issueKey)
        .header('Content-Type', 'application/json')
        .body([
        fields:[
                fixVersions: [[name: 'Version 1.0.1']]
        .asString()
if (result.status == 204) {
    println 'Successfully set version to 1.0.1'
} else {
    println "Failed to set version to 1.0.1 ${result.status}: ${result.body}"
Regards, Jon
Martin Brehovsky November 28, 2016
In the Script Runner for JIRA Cloud documentation is an example groovy script to calculate value of one custom field based on another as a Script listener. You can create new script listener to listen to Issue created event and based on the example set custom field value. Or if you want to copy custom field value once you can use Built-in script. Please have a look if that helps.
@Vasiliy Zverev or anyone else can you help?
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
