How to set workflow validators from one status to other when status change set to all
Prathap DL
We have workflow which user can change status from any to any. Now i want to add workflow validator from one state to other. How to do that?
For Ex: Workflow
Open--->All
InProgress--->All
Closed--->All
deferred--->All
Reopened--->All
With above example user can change the status from any to any.
Now i want to add validator from "Closed" to "reopened" only. the validator should work only from "Closed" to "reopened" only.
John Funk
Hi Prathap,
You would need to add another transition from Closed to Reopened. In my opinion you should get rid of the All transition to Reopened - that doesn't look like it should be something that is implemented because you wouldn't go from any of those other statuses to Reopened - just from Closed.
Prathap DL
Hi John,
Thanks for the Reply.
I just gave the example workflow. Actual workflow is different and user will go from any state to any.
John Funk
So, we need the exact scenario in order to provide the best answer.
Prathap DL
Hi John
If you look at the below Transition diagram, User can travel from any state to close. Now i want to add validator from "[QA] Updating DHR" to "Closed". whenever transition is moving from "[QA] Updating DHR" to "Closed" Maintenance workflow.png
