Hello all,
I am trying to setup an automation for a date picker. The situation is as follows:
For each ticket made in our project, a custom date picker is set to the last business day of that month (we'll call that field Customdate A for now). There is also a start date that I want to setup 5 business days BEFORE the Customdate A field. So something in the lines of:
{{now.lastBusinessDayOfMonth}} minus 5 business days.
My goal is then to setup the automation that whenever the value changes for Customdate A, the start date gets automatically populated based on the above values. Is this possible to setup? I haven't found anything on the official articles yet that could do something like this.
Hi @admin-nwalter,
Building further on that use case, you should be able to achieve what you want by referencing the value of your custom field and counting down 5 business days like this:
{{issue.Customdate A.minusBusinessDays(5)}}
Hope this helps!
Hello Walter,
This worked out great! Thank you for the suggestion.
