How to show subtask on Advanced Roadmap ?
Thierry Bouvet
I have create a Roadmap which contains Epic, stories and subtask.
If I create a subtask on a story, automatically I can show it in the roadmap:
I have created a new ticket type (as a story) but in this case, I don't see subtasks:
Any idea please ?
Andy Heinzer
November 7, 2023
Hi @Thierry Bouvet
I created a support case on your behalf over in https://getsupport.atlassian.com/servicedesk/customer/portal/48/PCS-225723
Please grant data access within that support case so that our support team can investigate this further to help out.
Andy
Becky Brooks - Visor for Jira
October 30, 2023
Timeline doesn't visualize Subtasks. Are you sure you're using Advanced Roadmaps and not Timeline?
Valerie Knapp
Hi @Thierry Bouvet , thanks for your question.
Is this a plan inside of a project? If so, please check the board configuration settings here -
that the child-level issue scheduling is enabled, the second option here ^
Does this help at all?
Thierry Bouvet
It is not inside a project, It is timeline in "Plans" menu:
Valerie Knapp
Hi @Thierry Bouvet , ok, thanks for the clarification.
More questions,
Does the DIG-65 have Subtasks?
Please can you check in the Plan settings that nothing is being excluded? If you can see other Subtasks, okay, they are not being excluded by type, but can you check please there aren't other restrictions in place? Including the date range to be included.
Cheers
Thierry Bouvet
Hi @Valerie Knapp ,
I confirm you that DIG-65 have subtasks.
I don't have any restrictions.
The only difference with a story is that it's a new ticket type (risk).
Cheers
Valerie Knapp
Hi @Thierry Bouvet , are the subtasks more than 30 days old?
Thierry Bouvet
Hi @Valerie Knapp
No the tasks were created 2 weeks ago.
Valerie Knapp
Hi @Thierry Bouvet , thanks for your patience. Do you have this option here, in the settings -
Please can you check what the result is for an issue key of one of the Sub-tasks?
Valerie Knapp
When I returned to the plan, when I modify the settings under Filter to include Subtasks in the hierarchy, I see the Sub-task I created
Thierry Bouvet
In the menu "Find issue", it seems to be ok :
But, my subtask are in the bottom (tasks not linked), they don't appear in the bottom of the parent key :
Valerie Knapp
Hi @Thierry Bouvet , thanks for your comment. I don't seem to be able to replicate this problem. I will escalate this to Atlassian so we can get you some help.
Thierry Bouvet
Do you test with a new type of ticket ?
itzmonk3y
October 30, 2023
b
