How to sum SubTasks story Points and compare with Story SP
Vikas Srivastava June 14, 2023
I have to write an automation rule which will do the following
Trigger -  When a story is re-estimated (Story Point is updated)
1. Sum all SP from SubTasks which are not one or Cancelled
2. Compare with Story SP
3. If mismatch is there then write a comment.
e,g,
User Story Story point = 4
  SubTask 1 - Status In Progress  - Story Point = 2
  SubTask 2 - Status Cancelled  - Story Point = 2
  SubTask 3 - Status In Progress  - Story Point = 4
Since there is mismatch between Parent US (4) and Sum and Active SubTasks (6) I want to put a comment.
I could compare
SubTasks points {{issue.subtasks.Story Points.sum}}  AND Story Point {{issue.Story Points}}. But how to exclude Done or Cancelled SubTasks is something I am not able to figure out.
I am sure it is simple tweak. :-)
Please help.
Trudy Claspill
June 14, 2023
Hello @Vikas Srivastava
Please show us your complete automation rule as you have currently built it.
How are you intending for this rule to be triggered?
Just added a snapshot.
Trudy Claspill
June 14, 2023
After the Condition where you are checking the Status of the trigger issue you can add a Lookup Issue Action to lookup the subtasks of that issue based on a JQL statement, retrieving only the subtasks that are not in a Cancelled status.
You could then use the smart value {{lookupIssues.Story Points.sum}} in the Compare Values condition rather than {{issue.subtasks.Story Points.sum}}
Like Vikas Srivastava likes this
let me try :-)
It worked. Thanks a lot.
Trudy Claspill
June 14, 2023
I'm glad I could help you.
If your problem has been solved, please consider marking the Answer as Accepted.
Vikas Srivastava June 15, 2023
Hi Trudy,
Now, I have to run the same rule on all stories at a scheduled time to get a report out of all the mismatches.
I have the JQL for getting the get impacted stories and compare then report all issues in an email to me.
