How to summarize custom fields values and put the sum into "Original estimate" ?
Vladimir Vladimirov April 21, 2021 edited
Hi!
I've created Custom Fileds
"Backend estimate" with the "Number" field type
"Backend estimate time period" with the "Select List (single choice)" field type
Also, I've created Custom Fileds
"Frontend estimate" with the "Number" field type
"Frontend estimate time period" with the "Select List (single choice)" field type
What is the best way to summarize the values and put the sum into "Original Estimate"
For instance, Backend ( 8 h ) + Frontend ( 8 h ) = Original Estimate ( 2 d )
Is it possible to do it using ScriptRunner Add-On?
Thank you in advance!
Vladimir Vladimirov April 22, 2021
Hi!
I've achieved my goal using Automation
We've decided not to use minutes and days. Only hours.
A trigger is  "Update Issue Field": Backend estimate, Frontend estimate
An action is "Update Issue Field": Original estimate
4h + 6h = 1d 2h
 {{#=}}{{issue."Backend estimate"|0}}*60+{{issue."Frontend estimate"|0}}*60{{/}}
