How to transfer or copy the issues from one project to another.
Merav Goldstein August 10, 2021
I am new in Jira environment and I opened a Team-managed project and wrote a lot of issues. I learned that parallel sprints can work only in Company-managed projects.
What is the possible solution for me?
1. Set up a new project and transfer or copy issues from one project to another? If so, how to transfer the issues from one project to another.
2. If there is a way to change the definition of an existing project from a Team-managed project to a Company-managed project?
3 votes
Jack Brickey
You might find this article helpful - migrate-between-team-managed-and-company-managed-projects
Hi Jack,
thanks for your answer.
1. I transtered all issues to the new company project (pic 2 green).
made a new sprint called: "Conceptual Prototypes Product"
moved some of the issues to the relevant sprint (pic1)
and I can see them in the board. (pic 4)
why I dont see them in the Roadmap?
2. additionally, please see the pic 2
epic 68 - I open this epic in the roadmap and that is why we see it in pic 3.
3. I updated the sprint inside the epic to the above sprint "Conceptual Prototypes Product" why I cannot see this epic in the Backlog under this sprint? (see pic 1)
4. as you see in pic 2 this epic has a due date. (yellow). where do we see this dates inside the issue?
as you see in pic 2 this epic has a due date. why I cant see this epic in th
Alex Koxaras -Relational-
Hi @Merav Goldstein ,
@Jack Brickey gave you a pretty good guide to start with, and work your way on.
So to answer to your questions:
  1. Yes, move to a CMP, using the guide Jack suggested
  2. No, there is no such way.
Alex
Merav Goldstein August 12, 2021
That helped me to move the issues but there were continuous problems:1.  problems with the time definition in all issues.The company projects handle time differently than team projects so I cannot see the DUE TIME in the boards and inside the issue.
2. I cannot see the issues in the roadmap. the only issue I see is the one I open in the roadmap itself.pic 4.png pic 1.png pic3.png pic 2.png
Read the story
