How to trigger an opening of a comment window when transitioning a ticket from state A to state B
Samantha Sharkov January 26, 2024
I need to put a setting/automation in place whereas:
When I transition a ticket from any State
to On Hold or Blocked
Then a comment dialogue pop-up should open
So that the user is reminded/forced to add a comment on Why they are moving the ticket to On Hold/Blocked.
Thank you!
5 votes
Walter Buggenhout
Hi @Samantha Sharkov ,
This is possible if you're using company managed projects and the workflows that come with them. If so, you
  • first of all need to have a comment screen in place
  • that your then associate with the given workflow transition
  • and add a fields required validator to the transition to force users to fill out the field
To create the screen, navigate to Jira Settings > Issues > Screens and create a new screen with no fields on it (this is because the comment field is always displayed, so you don't need to add it). Save the screen and name it e.g. comment screen.
Then edit your workflow. Locate the transition(s) to on hold / blocked. There should be a dropdown where you can add the comment screen to your transition.
On the validators tab of the transition options, add the fields required validator and select the comment field to be required.
Publish your update workflow and you should have a working solution.
Hope this helps!
Samantha Sharkov February 22, 2024
Thank you VERY much! Worked like a charm.
Nic Brough -Adaptavist-
January 26, 2024
Hi Samantha,
This is not something you do with Automation.  You need to edit the workflow and add a "transition screen" to the transitions into your hold/blocked status, then probably add a validator that demands that they make a comment or maybe set a field.
Bryce Lord
Hi @Samantha Sharkov !
To add a comment window when transitioning from one state to another, you'll need to add a transition screen within the workflow of that issue.
Just for clarification, is this within a team-managed or company-managed project?
BHUSHAN PATIL
January 26, 2024
Follow the steps mention in below article, this article will help you to add a screen to a workflow transition.
Also, if you feel my input help you please accept the answer.
Bhushan
