How to two way sync Jira - Trello and vice versa
Hayley Fell November 19, 2021
Hi all,
I've seen a few similar conversations on this and done some reading, but I'm still not clear...
What is the best app to use to sync Trello and Jira and Vice Versa?
What I'm looking to achieve is...
1. Trello cards created and will automatically create a Jira task
2. Jira task created which can sync and create a card in Trello
3. Any updates/comments etc to either Trello or Jira will automatically update on the alternative platform
Thanks in advance
2 accepted
Michaela Staffova
November 22, 2021 edited
Hello hello @Hayley Fell Michaela from Integromat here ðŸ‘‹
Just wanted to step in and say that this is something you could totally do with Integromat. To give you a bit of context: Integromat is a no-code platform that lets you connect Jira to pretty much any other online service and automate all kinds of tasks and processes ðŸ¤–
There are actually pre-made templates for what you're looking to do
You can pretty much just grab these, set them up, activate them and watch the automation magic run 🙂
To get yourself started, you can simply sign up for a free Integromat account and get the ball rolling.
PS: To learn more about Integromat, you can check out its listing on the Atlassian Marketplace
Hayley Fell November 23, 2021
Thanks Michaela, I'll have a better look into this!
Like • Michaela Staffova likes this
Michaela Staffova
Sure thing, Hayley! Feel free to let me know in case you need some extra info or a bit of assistance ðŸ™Œ
Peter Cselotei
April 7, 2022
Hello @Michaela Staffova
Could you please re-link these templates, now the Integromat is called Make and the links not working.
Thank you!!
Peter
Chris Buzon
November 19, 2021
https://marketplace.atlassian.com/apps/1217147/trello-jira-two-way-sync?tab=overview&hosting=cloud
I've never really been able to make syncing b/w Trello and Jira work as easily as you might be hoping, but this company makes other sync-apps which do work pretty well.
Thanks Chris - think I'll just have to get a free trial of this and see how it goes
FREE
