Is there any way to undo changes made for bulk tasks?
We accidentally updated 'Fix versions' for 200+ tasks and would like to undo the action.
We could track the changes by looking at email notifications and manually update the Fix version revert back to the original, but I appreciate if there is a better way to proceed this.
Thank you.
Hi @Kazumi Kerr
I learned this the hard way that reverting changes can be a big hassle, so what I started doing I always add a new label like "2021-12-05_bulk-change" to those issues (or couple of more labels). If you are doing the bulk change using a script then fetching the change history for recent changes can also work apart from what @Jack Brickey and @Florian PEREZ [Valiantys Administrator] suggested using JQL.
Ravi
Yes this! One of my favorite tricks when making bulk changes is labels.
That's good to know to add labels to those bulk changes in case we need to revert back. Thank you for your suggestion!
It depends on whether you can establish a JQL filter search that resolves in the previous bulk edit. For example, maybe something like this…
Let’s assume that your bulk edit and it was done today. Let’s also assume that no other issues were updated today that have the same fix version. then you could use the following JQL to result in the same list of issues that were previously changed.
project = xxx and updatedDate > startOfDay() and fixVersion = yyy
then you could use bulk edit to change the fix version again. Obviously there’s some underlying assumptions here that I may be missing but hopefully this gives you something to consider.
If you modified the issue you can also add your name in the query to restrict even more the result.
You can check for the time the mistake was done in audit log and add this to the query to.
By doing this you should be able to modify back the value.
There's one big assumption we can add this is you want all the the issue back to the same version witch is a very low probability.
If you want to check all issue one by one you don't have to wait for email, you can also go into the history of the issue to get the old version.
If you know well enough scripting you can try to:
That's being said it's a lot of work and this request has very low chance to be used again, so I wouldn't spend time on this unless it's either a challenge you want to try or an absolute necessity!
Good luck and I hope this help!
@Jack Brickey & @Florian PEREZ [Valiantys Administrator]
Thank you for your suggestions! We will definitely look into it.
