How to update an another issue in different projects?
jun lee
January 13, 2022 edited
I created a project automation rule to create an issue to a diffrent project. (A project issue -> B project issue)
I would like to make a project automation rule from the B project to update the A project issue when the B project issue). Do you know how to this?
In conclusion, I want ..  A project issue creates B project issue, and then B project issue updates A project issue''s status.
Pramodh M
Hi @jun lee
Welcome to the community 🙂
Use Global Automation Rule and select the scope for two projects
Now to check the projects issues use jal to restrict the issues to specific project
That should solve the requirement
If you could explain what exactly what you are doing it would help
Pramodh
jun lee
I want to set-up an automation rule like below image.
FREE
