How to update only a few fields with JSON import?
iotim
I'm getting the following error:
"1 of 1 issues have been skipped because they already exist in destination projects."
All I'm sending is the key and a custom field.  Any advice?  Is this possible?  Below is my sample JSON.
    "projects": [
            "name": "MyProject",
            "key": "AB",
            "issues": [
                    "key": "AB-50",
                    "customFieldValues": [
                            "fieldName": "User\/Customer",
                            "fieldType": "com.atlassian.jira.plugin.system.customfieldtypes:textfield",
                            "value": "Test"
iotim
Well, I don't think you can.  Instead I wrote a php script using curl and basic authentication.  For the next guy, the following links helped me.
https://developer.atlassian.com/cloud/jira/platform/basic-auth-for-rest-apis/
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issues/#api-rest-api-3-issue-issueidorkey-put
iotim
Can anyone help with this?   I really don't want to write an app just to do this simple task.  I looked into CSV import to alter a single field, but it says that if you do not send all the fields, the ones not sent are set to their defaults.  I can't believe there isn't a method to do an update via JSON.
Register now
