How to upload custom priority icons in Atlassian Cloud?
Rob Moore
February 4, 2016
This question is in reference to Atlassian Documentation: Customize your site
We are transitioning our JIRA over from a standalone instance to Cloud. We have custom priority icons that I'm trying replciate in our Cloud instance. I don't see any way to upload icons for priorities like I can in other areas of the site. I tried using the webdav folder as a source for the icons but now it requires everyone to have webdav access to use JIRA (that is, it prompts them for their webdav password every time they login). Is there another way to skin this cat?
Rob
3 votes
Steven F Behnke
February 4, 2016
  • Upload them as an Issue attachment and don't delete it
  • Upload them to a Confluence page and don't delete it
  • Convert your image to a data URI and paste that in the location area
https://jira.atlassian.com/browse/JRA-21246
Steven F Behnke
February 4, 2016
I get the same HTTP 500 but it seems to work anyway. I lifted all these suggestions from that issue I linked.
I think that Atlassian is slowly improving all UI aspects, but this is not a priority (heh) for them right now. JIRA team has said this year they are focused on configuration simplification, bug fix/data center improvements, as well as other needed functional items like Issue Linking events etc.
Unfortunately custom icons will just have to get rolled out when someone takes it on as a personal project or when internal UI improvements become an active epic.
Rob Moore
February 4, 2016
Well, I spoke too soon. It works in the priorities config page but fails when you go to other pages that reference it. The URL ends up looking like this:
https://example.atlassian.netdata:image/png;base64,iVBOR...
Kevin Fox
July 4, 2022
Brilliant.  this works like a charm
19 votes
Joshua McManus
A solution!!
  1. Use the issuetype icon editing/uploading function
    1. go to Issue Types in Jira Settings > Issues > Issue Types
    2. Edit an issue type (either existing or create a new one)
  2. Change the icon for that issue and upload your own png
  3. Save that change
  4. Right-click the icon on that page and copy the image url
  5. Go to Jira Settings > Issues > Priorities and edit the priority you want to update
  6. Paste the url into the image field
  7. Save
  8. Profit!
KJ.Anderson
February 12, 2019
That's issue type, not Priority.
BrianW
That is brilliant Joshua!  Thanks!
KJ, try reading it all before you say it's wrong.
Like 2 people like this
marcus.hirt@datadoghq.com August 20, 2019
@Shwetha Suvarna - it seems Josh way is the only way to get this to work, if you want to get the icons from Jira Cloud with the rest of the content. Is there a less clunky solution?
marcus.hirt@datadoghq.com August 21, 2019
Found the less clunky solution (see below). That said, those icons don't seem to get cached in the browser.
Pablo Martinez
January 9, 2020
Thanks Joshua! It worked like a charm.
the url will be something like:
/secure/viewavatar?size=xsmall&avatarId=111111&avatarType=issuetype
But it works
Like Edwina Cooper likes this
Edwina Cooper
February 4, 2021
Thanks so much for posting - really helpful!
marcus.hirt@datadoghq.com August 20, 2019 edited
It seems like it is possibly to do this by uploading the icons to an issue. The important part is to then go to "Manage Attachments" in that issue (which I could not find in the new layout, so switched back to the old layout), and then copy the url directly from the link at the file name. Do not follow the link and let that URL resolve. Use the link as it is under "Manage Attachments".
Like Bency Ebenezer likes this
Mark Mermelstein
February 5, 2020
Better to use SVG icons rather than PNG if able.
aarti rajput June 5, 2020
This solution works , but what if any user do not have access of issuetypes then i think he wont be able to access the image url in priority.
Tobias
November 25, 2020
@Mark Mermelstein this task is a bit older but i have problems with the display size of my custom priority icon. Do you have any idea how i can scale this a bit bigger. I use SVG, normally this should scale itself.
Lindsay McMahon
May 19, 2022
Awesome hack! thanks @joshuamcmahus
Register Now
