I saw a workaround using JQL Queries in this documentation, but it doesn't actually work. The security containers are very important to our devs knowing at a glance where to go to fix the vulnerability.
Would love to, at the very least, be able to query which vulnerabilities are from which containers, but alas - this information seems locked inside the security tab of each project.
@Sarah Derr Please note that a JQL query will always search for issues!
In this context, you can search for issues that are affected by vulnerabilities of certain priority, keyword, etc., but it is important that these are issues! You cannot use JQL for searches like "which vulnerabilities are affecting the following issues".
I know that there is a custom field "Vulnerability" which you can add to the Issue Navigator as a column, but in my experience it doesn't show anything, but empty cells. (It seems like a bug or a missing feature.)
