How to use a post function to create a subtask depending on what field is selected.
Omari Ledeatte-Williams January 11, 2021
I have a  created a post function using scrip runner to create a number of subtasks. At the moment when the item is transitioned to the next phase in the work flow all the subtasks are created. I only want the corresponding subtasks to be created depending on what option is selected. Can anyone help with this?
Jack Brickey
Post Function won’t get you there. Look to create an Automation rule...
trigger - issue created
condition - field value
action - create issue
Register today
