How to use if condition in Additional fields
Peyush Agarwal
so I want to create an Automation Rule in Cloud
What I want is suppose there is custom field as "Project Manager Name"
if Project Manager name is "Peyush Agarwal" then change it to "Peyush Gupta" else it should remain same
I tried writing
"fields": {
If ("Phase Detected" == "Phase Detected": {"value" : "Production Phase"})
"Phase Detected": ""
"Phase Detected": {"value" : "None"}
But looks like I am not able to write proper code. Can you please help
Bibek Behera
Hi @Peyush Agarwal ,
I am not that familiar with the automation, the way I would approach this is to use the bulk update with a JQL which has custom field which need to change. Using JIRA bulk update you can change the value of the custom filed at ones.
-Bibek
