How to use the JIRA cli to automate release?
Connor Conway
November 5, 2021 edited
Hello there,
Is it possible to use the JIRA CLI to automate a release? I couldn't find any documentation on the release part but hopefully I'm just looking in the wrong place.
I'm hoping for something like:
1. Get all tickets in the "Selected for development" column in a Kanban board with a specific component.
2, Release obtained tickets and tag a version
3. Create release notes from JIRA description content
3. Move all tickets to "Done"
We have a DevOps pipeline that this would be done as part of.
Here are the Docs I was currently using:
https://docs.jiracli.com/#config
Thank you,
Connor
Kinnera _Appfire_
November 7, 2021
Hello @Connor Conway
We have created a support ticket for this requirement in our portal and we would like you to sign up for our portal and let us know the username so that we can make you the reporter and you will be able to access the ticket https://bobswift.atlassian.net/servicedesk/customer/portal/1/SUPPORT-8437 for further progress.
Please find the below link to signup to the portal:
https://bobswift.atlassian.net/servicedesk/customer/portals/1
Kinnera
sravya.chintalapudi {Appfire} November 8, 2021
Hi @Connor Conway ,
As said earlier, we have created a support request in our portal https://bobswift.atlassian.net/servicedesk/customer/portal/1/SUPPORT-8437 for further discussion.
The below Jira command will help you update the fixversions and transition the issue of a set of issues.
--action runFromIssueList --jql "project =TEST AND component = COMP1 AND status in (Open)" --common "--action transitionIssue --issue @issue@ --transition 11 --fixVersions "1.0""
Here the transition "11" is the ID of the status you would like to move the issue to.
Please try the above command and let us know if you have to face any issues.
Sravya
Jack Brickey
That doc is for Server. Some things you could consider/assess…
  • use Automation (manual trigger)
  • consider a devops automation addon from the Marketplace
