Hyperlink in issue created by api client
Manuel Ruiz
May 29, 2023
I am creating an issue on my Jira Cloud server with a slack bot that uses a Version 3 Jira api client. A hyperlink is part of the issue summary (e.g. [link|url]). The problem is that it does not show as a hyperlink when the issue is viewed online. Curiously, when the Jira slack app notifies me of the issue creation, the hyperlink appears correctly in the app notification.
Trudy Claspill
If you type a URL into the Summary field directly in the UI do you see it rendering as a hyperlink? I don't see that happening in my cloud system.
I think the Summary field is just a plain text rendering field.
Manuel Ruiz
June 1, 2023
I think you are correct. Thanks!
Help us plant more trees
