Issues:
My board is configured so the Backlog view excludes initiatives and themes
The Advanced roadmap can be pointed to the board view or project view, board view does not work as an input source as it removes the themes and initiatives that I plan to use in the roadmap hierarchy.
Selecting the project view means I dont have the sprints to assign to plan teams
Hi @Neil Wills,
You can add multiple issue sources to a single plan in Advanced Roadmaps. So use the board as an issue source for your actual work (the epics and the issues below the epics) and add an additional source (that you can base off a saved filter) to add your initiatives and themes. That way you should get both chicken and eggs in the basket!
Hope this helps!
Learn more
