Sign up Log in
I can not transition an issue only to "to do" status
Valerie Verveda
I can not transition an issue only to "to do" status on the kanban board. Other statuses are fine (i can do the transitions.
I checked all is fine with workflow (transitions are the same in other statuses as in "to do" one).
I CAN transition to "to do" not via the drag and drop on the kanban board, but only by clicking "more" on an issue, and selecting "more"- > "move to to do". So I am confused. I can transition it only via this way, not drag and drop.
Alex Suslin
December 16, 2016
Check underlying workflow for that project. There should be link from TODO to other status.
Valerie Verveda
I checked that before. there are transitions from all the statuses to "to do"
Deleted user December 16, 2016
Check your board configuration and make sure the 'To Do' status is in the To Do labeled column. If you need more help, check here;
https://confluence.atlassian.com/agile/jira-agile-user-s-guide/configuring-a-board/configuring-columns
Valerie Verveda
Hi Tom, thanks for a fast reply!
It is there . see here http://joxi.ru/gmvY9pwugky5ra
So this is not the case. The issue is in some other place. I can't find the reason why it does not work. Could you help investigate?
So you are trying to move it from what column to the To Do column?
Valerie Verveda
From any other column.
