×I do not have advanced filter (not sure why) only basic. The date range does not work either. I see date created but when I try to create a range using any of those fields and hten search, it is blank output.
Hello @Shahrzad Shariati ,
I think we might be able to help better if you provide us a screenshot of the view you are currently using with the blank results. This should give us the context to help guide you.
Kris
For the first issue: The advanced search this is all I see:
For the date range, seems to be working today. I was not seeing an output. All good there now!
The advanced search is shown currently on the screen. The basic search has been highlighted in red on your screenshot.
createdDate > "2017/11/20 22:00" AND createdDate < "2017/11/21 6:00"
Yes, it is not the correct behavior not to have advanced filter. May want to submit a ticket to Atlassian support to get that checked out.
However, when you do get advance search back up again, follow this link for examples to perform data range search:
https://community.atlassian.com/t5/Jira-questions/JQL-for-Filter-by-date-range/qaq-p/947641
Hope the helps.
-Ben
