I changed the RANK field in my project/board filter and now get an error
gagneet June 16, 2019
I changed the RANK field in my project filter, as someone else had a similar named field in another project and that was conflicting with the one I had in my project. Now I get the following error whenever I try to go to the Board:
"illegal entity scope for entity class (custom_field). expected entity scope 'global' but has scope 'project'"
Is there a way to correct this?
Ravi Varma
June 17, 2019
Hi @gagneet ,
Rank custom field is exclusively used by JIRA Software for ranking tickets. No one should be changing/modifying them. You should revert back to the old state and request the other stakeholder to change that custom field.
Please go through the Notes section in  enabling-ranking Atlassian documentation
Ravi Varma
gagneet June 17, 2019
Thanks Ravi. The issue is that I changed the filter to remove the rank, and now I am getting the above error whenever I try and browse to the board. I am unable to go to the "Board Settings" menu again to change the filter or do anything.
Is there some other way in the Cloud JIRA to rectify this issue?
Ravi Varma
June 17, 2019 edited
Hi @gagneet ,
  • Go to Search.
  • You will see Filters at the bottom. Click on it.
  • JIRA will show the filters.
  • You need to identify the filter that is used in the JIRA board.
  • If you are the owner of the filter, you can modify the filter JQL. Rank custom field has large significance in JIRA Software. Please be careful with that
  • Click Save
Please accept my answer, if it helped you solve your problem.
Ravi Varma
Thanks @Ravi Varma that helped out and we were able to resolve the issue.
