×1. Created Sub task issue type
2. When i try to create Sub tasks I am not getting any option to choose my created sub task issue types.
Please help
A project can only have one issue type scheme. The issue type scheme tells a project what issue types are available to it. It's complete nonsense to have many - which one would you use to determine what issue types are available when someone clicks create? Or what to do when someone tries to change the issue type?
If you want to add a sub-task type to the project, you need to add it to the issue type scheme. Either add it to the existing scheme, or create a new scheme and then associate the new scheme with the project.
Once you have done that, you will find that you can create sub-tasks in the context of an issue, it's in the options menus across the top of an issue (you can't create sub-tasks outside an issue, a sub-task is a fragment of an issue, not a separate entity)
Hi @Meenakshi G,
There may be quite a few reasons for this:
Hope this helps!
Thanks.
I am working on Company managed projects only. I already have an issue type scheme associated with that project.
Now i am try to add sub tasks under Story issue type.
If i try to assign this Story issue type scheme, system asking me to update existing one which i dont want to disturb.
Can we assign multiple issue type scheme for a project. Please help
