I uninstalled Insight by Accident and I'm afraid I lost all my Inventory. I looked in the app store and I no longer see Insight for Atlassian Cloud.
Is there a way to get it back?
@Nicole HatchYou can re-install the plugin again, uninstalling the plugin will not delete the tables created in the database for that plugin and all the plugin data is stored in database. once you again installed the plugin it will read all the data from existing tables and you should be good with all your plugin data.
Please re-install the plugin and let me know if can see the old data or not.
Uninstalling a plugin does not delete the data from the database. If you install the plugin again data should be back. You should contact Atlassian/Mindville support if you can't install the plugin again.
