I use Jira and my client does as well. Can I connect both Jira?
William Suzuki
May 20, 2021
My company is developing a Product for a client that has other clients developing other products for them, that is why they use Jira, so they can connect activities and keep their pipeline.
My company as a software company also uses Jira, but we have some plugg-ins that we use internally for our management.
Is it possible do connect both Projects one in my internal Jira and the other in my client's Jira in a way that what I edit in one reflects to the other?
Martin Bayer _MoroSystems_ s_r_o__
Hi @William Suzuki it is not implemented in Jira by default.
But there are some products (I know Backbone - https://marketplace.atlassian.com/apps/1215199/backbone-issue-sync-for-jira?hosting=cloud&tab=overview) which are easily configurable to achieve what you (probably) need :).
You could probably manually configure Automation or write Scripts (Script Runner) to achieve this, but it would be more complicated...
Daniel Lecoq June 15, 2022
Hi William,
Did you find a solution for your purpose ?
Currently, my company uses Backbone Issue link to connect a Jira cloud instance with a Jira Datacenter. We own both Jira instances, so it's easy to manage syncs with Backbone. We can indeed create service users, get tokens and manage roles in all projects. Backbone works well, but we configured it to push data from cloud to datacenter. It's not a fully synchronization.
Soon, we need a solution to connect our Jira Datacenter with a partner's Jira, who develops some functionalities for us. We are not completely confident with this solution. I wonder if Backbone is the good solution for this use case.
Best regards,
Daniel
Liset de Bruin _K15t_
Hi Daniel,
Liset here, product manager of Backbone Issue Sync at K15t. With Backbone you can sync issues between different instances also across organizations. I’m not sure what exactly you want to achieve with the connection but I’d be happy to discuss that with you and if Backbone would be a good fit for that.
Feel free to reach out directly to support.k15t.com and then we can take a look.
Liset
Like # people like this
Deleted user May 20, 2021
Hey @William Suzuki
Are you planning to develop it yourself or are you willing to use an intermediate app?
If you are willing to use an app. Here is an explanation of how you can do it with Exalate (the add-on I work for)
IF you are still considering developing the integration yourself you might be interested in this post:
Let me know if this helps,
