I want to add a sub task to a sub task (4+ operation levels).
Elizabeth Sangers
August 10, 2021
Some sub tasks seem to have the option to add another sub, but others don't. Any ideas why that is?
Is there an operation level max?
Epic>Story>sub task>sub task2>sub task3
OP1>OP2>OP3>OP4>OP5
Jack Brickey
I have never seen this before please share a screenshot of where you are seeing this so that I might be able to comment further.
Elizabeth Sangers
August 10, 2021
I think my version of Jira only has 3 operation levels, so this isn't possible.
Seems very limiting when designing planning software :(
Nic Brough -Adaptavist-
August 10, 2021
You are correct, Jira only has Issue and Sub-task.   Jira Software layers Epics over Issues, but there's no sub-task of sub-task.
A desire for sub-task of sub-task is usually indicative of either wasteful micromanagement, or that you've started your planning at too high a level - look at moving stories up, as they're probably really Epics.
You can get apps to do sub-task of sub-tasks though - specifically, look for Structure, it's the only one I've used for this sort of thing.
Like # people like this
Dave Rosenlund _Trundl_
Hi, @Elizabeth Sangers. You can find Structure on the Atlassian Marketplace if you want to have a look.
Structure was originally created because of a popular Jira enhancement request from someone who was looking for sub-tasks of sub-tasks.
Hope this helps,
-dave [ALM Works]
Del Jensen
August 10, 2021
To add to @Nic Brough -Adaptavist- comment, use the linking feature.  This is done before/after this, this has to be done first/last, this has to be done parallel to this, etc.
In a Gantt chart, it looks like you have sub-tasks and sub-sub-tasks and sub-sub-sub-tasks, but they are really all tasks just linked in order of how they should be done.
