I want to count how many child issues have a status of 'Closed' and put that count in the parent iss
koutarou ishibashi
I'm not very proficient in English, so I might be mistaken, but I want to put the count of child issues with a status of 'Closed' in the parent issue's field using Jira Automation. Can you please advise me on how to do this?
Tom Lister
September 19, 2023
Hi @koutarou ishibashi
If you want to use automation, you can use something like this
"Word Count" is a convenient numeric in my setup.
Its value is being set to
{{lookupIssues.size}}
that is the results of the JQL lookup
There are pros and cons to using editable fields vs read-only scripted fields that would depend on your use case.
What are you trying to solve?
Tom Lister
September 19, 2023
koutarou ishibashi
Thank you for your answer. It was solved by implementing it as I was taught.
Tom Lister
September 20, 2023
If one of the answers solved your query, could you mark it as answer accepted for other members to find.
Like koutarou ishibashi likes this
koutarou ishibashi
I'm sorry I don't understand the meaning
Tom Lister
October 2, 2023
If you have got an answer to a question that solves your problem, you can click the "Accept Answer" button to indicate to other users with a similar issue that there is a fix.
Best
Tom
Raja Shekher
September 19, 2023
Hi @koutarou ishibashi - You need to have a Scripted field which is available via Script Runner Plug-in and do something like below
import com.atlassian.jira.issue.search.SearchProvider
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchProvider = ComponentAccessor.getComponent(SearchProvider)
def customField = customFieldManager.getCustomFieldObjectsByName("FieldName").first()
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
// jql query to get the Child Issues with Closed issues
def query = jqlQueryParser.parseQuery("issueFunction in issuesInEpics('project in (MyProject) AND status = "CLOSED')")
def results = searchProvider.search(query, user, PagerFilter.getUnlimitedFilter())
//Get Results
def result = searchService.search(jobUser, query, PagerFilter.getUnlimitedFilter())
def issues= result.getResults()
//log.warn("issues are" + issues)
return issues
koutarou ishibashi
Thank you for your answer. JIRA Automation solved it
FREE
