×I would like to see Time in status without using any 3rd part app. How do i see time spent on each status?
Hello @Ashokkumar D
If you are not willing to use a third party app, then you will have to create custom issue fields for holding that information, one per status, and automation to fill the information into those fields.
Thank you Trudy for the information
Do you have the automation pipeline screenshot for this model? Can you please share?
No, I don't have an automation pipeline for that. I'm not sure that it can actually be done.
Here is the home page for the documentation section that concerns Automation.
https://support.atlassian.com/cloud-automation/docs/jira-cloud-automation/
I think this will be a difficult rule to construct.
Yes I'm aware of the automation pipeline but not sure whether this can be done
