I am using the "Version created" trigger in Jira automation and trying to use the smart value {{project.key}} to identify which project the version was created in as I need this for future steps, however this doesnt seem to work.
I understand that I could create my automation rule to be project specific and then hard code the project key but this means that I will need to create multiple copies of 1 automation rule for all my projects rather than 1 that runs across all projects. The overhead on updating these is then bigger.
I am not sure if I am missing anything obvious...
Any ideas?
How you are using the version created trigger, maybe you need use this smart value to access information about the version {{version.project.key}}
Give a try and let me know if this helps you.
Best Regards
Thanks for the quick response @Kawan Diogo
That seems to have worked. I had a look at the smart value documentation but couldn't see the version related ones. If you have a link you could send across that shows these it would be much appreciated.
There is no section talking about this smart value, but there is documentation on how to discover smart values here: Find all available smart values for a Jira issue
Smart values like that are listed under the "development" section in the documentation:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-development/#--version--
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
