I have a simple form created in Office 365 where people can upload attachments, including images. This form is connected to Jira through a microsoft flow. The ticket creation is working great, however the image appears as an un-clickable URL rather than as an image. Is there any way to make this appear in the ticket?
Hi Sarah.
In the Power Automate flow you can put in the 'Create a new issue' step that put what it retrieves from the Attachment field and it will write something like this:
[{"name":"image.png","link":"https://my.sharepoint.com/personal/user/Documents/Applications/Microsoft%20Forms/Create%20Issue%20(Jira)/Question/ image.png","id":"01K5HU62TE4MGT47UVC7JCKPHBUBVFDAYOP","type":null,"size":312201,"referenceId":"01K5HU262XESD3LAI6P7ND35VX3RPKGBU46","driveId":"b!8o22RPSOaAJ0qcracV3D5hmFBuJJu02MtOrTbn4g4lWYnc5jstatkdA"," uploadSessionUrl":null}]
Link paremeter is the URL to the image.
In Jira you can create a job with scriptrunner that is launched with the 'Crete Issue' event, which collects the previous text, takes the link value to put it in the description and that way it will be a working URL.
Can someone support with just extracting the https link from the string of text with power automate. I was looking to use the "slice" function and point to the start of the string with "https:" and the end to the string with ".png" . Is this a viable option to extract the https url?
Having a similar issue due to the attachments being auto-saved in file structure through MS Forms- even unable to send file URL directly through API call to create/update Jira ticket. Any and all pointers to get the file from Sharepoint into Jira ticket would be greatly appreciated.
(get '415 error for Unsupported media tye as soon as I try to access the MS Forms created file URL. )
Side notes
- API call works fine if I replace file URL with URL for public random picture
- All our Jira users have access to the file folder in Sharepoint
ended up being able to parse the attachments collected using:
We can't tell what text your submitting to the ticket. If you provide that information, it's possible someone here can be of some help.
Sorry, do you mean you need to know what text is being submitted to the Jira ticket? The issue isn't the text but the images that are being submitted to the ticket that aren't showing up.
