Import ProjectPlace Projects into Jira Software
Michael Stern
October 31, 2023
I want to import projects from ProjectPlace to Jira. Can it be done?
Walter Buggenhout
Hi @Michael Stern and welcome to the Community!
If you can manage to get the data from ProjectPlace into a csv file, you can import them into Jira using the csv import function. Guidelines on how to properly format your csv source file and running the import can be found in this support article.
Before you start running any import, make sure that all the fields you need to import exist in Jira and are configured properly for the project(s) you want to import your data into.
Hope this helps!
