Importing to excel without need to add username/password
Adam Lee April 16, 2020
I currently import data from a JIRA board/filter to Excel using the power query with basic credentials type and then username/api key for the log in. This topic is covered extensively in link below. I find once the data is in excel it can be manipulated very easily and the dashboards that can be produced are very useful. I then have a refresh button that repeats the power query import and updates the dashboards (is this considered a rest API)?
https://community.atlassian.com/t5/Jira-questions/Fetch-data-from-JIRA-to-excel/qaq-p/198786
My issue is that only i can refresh the dashboard due to the basic credentials setup and would like to have it set up in a way that anyone in the company can open the file and refresh the data. I have added the username and password to the URL on other ticketing programs - redmine etc, however i believe the os_username&os_password has been disabled from jira.
https://confluence.atlassian.com/jirakb/jira-cloud-os_username-and-os_password-embedded-in-url-no-longer-available-868988403.html
Is there a workaround? This has been bugging me for a while, any help is greatly appreciated.
David_Bakkers
April 26, 2020
Since you're using Jira Cloud, you'll have to switch to using a token for the authentication, not basic authentication with username / password.
Still, each user will need to generate their own token for their account and use it to make the query.
