×I have tried and tried to figure out the format for worklog import/updates onto Cloud and for the life of me, cannot figure it out!
Can anyone help? Here is my entire CSV :
Summary,Issue key,Issue id,Worklog,Worklog
Customer was allowed to place order without providing email,FINTS-70,88038,Working on issue FINTS-70;22/Sep/22;james@logicspot;600,Working on issue FINTS-70;22/Sep/22;james@logicspot;900
Using the built-in, Cloud CSV importer I receive:
<p>Unable to import worklog com.atlassian.jira.plugins.importer.external.beans.ExternalWorklog@25ce3297: Worklog for issue with id 27523 did not pass validation due to errors Errors: {timeLogged=Invalid time duration entered.}</p><p>Error Messages: []</p>
Anyone any ideas please?
Hi @Mark Haller ,
as described here https://support.atlassian.com/jira-cloud-administration/docs/import-data-from-a-csv-file/, a worklog should have the following format
Your CSV file can contain worklog entries. For example:
Summary,Worklog
Only time spent (one hour),3600
With a date and an author,2012-02-10 12:30:10;wseliga;120
With an additional comment,Testing took me 3 days;2012-02-10 12:30:10;wseliga;259200
I think that you ned to update the worklog date format in your file.
Fabio
Hi Fabio
Just tried this and it fails. This is my file -
Key,Summary,Worklog
FINNS-70,Only time spent (one hour),3600
FINNS-69,With a date and an author,2012-02-10 12:30:10;wseliga;120
FINNS-68,With an additional comment,Testing took me 3 days;2012-02-10 12:30:10;wseliga;259200
I then receive:
2022-09-25 16:23:46,882 INFO - Only new items will be imported 2022-09-25 16:23:46,974 INFO - Importing issue: [externalId='autoid--1100892491703224869', summary='Only time spent (one hour)'] 2022-09-25 16:23:47,347 INFO - Importing issue: [externalId='autoid-2863127554186853816', summary='With a date and an author'] 2022-09-25 16:23:47,545 ERROR - Unable to import worklog com.atlassian.jira.plugins.importer.external.beans.ExternalWorklog@6de14c54: Worklog for issue with id 27582 did not pass validation due to errors Errors: {timeLogged=Invalid time duration entered.} Error Messages: [] 2022-09-25 16:23:47,556 INFO - Importing issue: [externalId='autoid-3266778303944090329', summary='With an additional comment'] 2022-09-25 16:23:47,766 INFO - 0 out of 3 issues successfully created
And then when I check the issues, no worklogs show on the issues screens. Even worse, when click Activity -> I see "Something's gone wrong" as a popup, with "ERROR: HNYO8S"
Hi @Mark Haller ,
I believe I see 2 problems with your file.
Hi Hana
Thanks for the quick reply!
the format is actually from JIRA server Export all fields on the query screen.
how would I export the work log data from JIRA Server quickly and easily from my projects to be able to import into Cloud (this is not using the migration tool)
I was able to make this work. my file looks like this:
Key,Summary,Worklog
TK-80,Test worklog issue,Worklog text;25/Sep/22 3:30 PM;user-account-id;3600
TK-80 - change it to your issue key
Test worklog issue - change it to your issue summary
25/Sep/22 3:30 PM - format here is dd/MMM/yy h:mm a (import default) - it is possible to have different datetime format, but you need to set it during the import
user-account-id - instead of username in server/DC you need to use your user account id in cloud
3600 - time spent in seconds
Please try.
