Dear all,
We have a free jira instance on which we would like to install the plugin JEMH cloud fro different tests.
When requesting it from the Find new app section, then afer clicking on Try it, it start to try to install and then stop without any error and plugin is not installed
Any idea what could be wrong or does others meet same scenario ?
regards
What errors are you getting?
we did not get any error, this is the wierd things.
Simply it stop
This may help you Serge: https://community.atlassian.com/t5/Jira-Service-Management/Unable-to-install-apps-from-ATLASSIAN-MARKETPLACE/qaq-p/1478888. Sounds like it could be due to Jira trial expiration.
Hi Serge,
This should "just work", and we have tested that it does so using a new cloud site. Please can you open a support request with Atlassian?
Mike
