In Jira cloud with Google Chrome, I cannot see any attached emails. It worked fine before, but now I get a: Oops... Failed to load the panel.
I checked different browsers:
The problem occurs only in Chrome (Version 88.0.4324.190) under Windows 10.
What can I do to solve this?
I found a solution that works for me...
In Google Chrome, click on the "lock" icon left in the address bar --> click on "Cookies" --> click on tab "Blocked" --> Click on the domains listed there, and then click "Allow" button on buttom of window!
Seems that Atlassian fucked up some cookie cross origin (CORS) settings...
Hi @Jan1908 ,
I must assume that you already tried clearing the cache on Chrome or using the Incognito option, no?
@Jan1908- can you attach a a full-screen screenshot? (please mark with black all the data that is confidential)
@Jan1908- make sure that you don't have add-ons that can block this from loading in the page. If you have add-ons installed on your Chrome, temporary disable them and try to see if this still occurs.
My guess is that something from the browser is preventing that part of the page from loading and it crashes or it gets blocked.
