In Jira Agile when we move an Issue from In Progress to Resolved Column no window oppened to add comments
informaticaccpe June 9, 2015
In JIRA Agile when we move an issue from the column "In Progress" to resolved, the pop up to add coments it isn't showed. But when we move to resolved from other columns the pop up to add coments is showed.
How can we fix it to show pop up comments when we move from progress to resolved column ?
Thanks.
Rahul Aich [Nagra]
June 9, 2015
You will need to add the transition screen with the comment field on it for the transition Progress to Resolved.
You will need to create a screen and then go in andedit your workflow and associate that screen in the relevant transition
Rahul
