I would like to customize the workflow of a new project of type "Team-managed software". A part introducing custom statuses and transitions, can i customize the substatuses ?
For example, I would like to have Closed: Rejected, Closed: Duplicate and Closed: Won't Fix.
Thanks for your help and patience!
S.
Few options for you to accomplish this with the team managed privileges:
Thank you bduncan!
You make me realise that option number 2 - Resolution - is the standard way to go :)
