I'm trying to add the Sprint field to the issues in a next-gen project, but I'm not able to do so. I went to Project Settings/Features and see the Sprints toggle, but it's grayed out. Any other options without having to create a new project and move everything over? :(
Thanks in advance!
Brad
Stumbled across the answer myself finally. You first need to enable the Backlog, and then the Sprints toggle will no longer be grayed out.
@Brad Lackey, underneath Features, make sure Backlog is turned on first. You cannot enable Sprints without Backlog turned on.
Kian
Read the story
