The goal is to count number of URL occurrences as plain text (number of "https://url.com...") and display those as a field.
To start learning I tried creating a smart value the dumbest possible way {{issue.NumberOfEdits}} and on case edit {{#increment}}{{issue.NumberOfEdits}}{{/}} but it doesn't look as it works?..
I have not heard of NumberOfEdits before. Where did you see that one?
Another way to count those URLs is using the split function and counting the list items:
{{#=}}{{issue.description.split("https").size}}-1{{/}}
How this works:
Best regards,
Thank you for your reply.
That smart value is something I tried to create myself (when ticket is created - create smart value) to later operate it and to learn about them more.
I tried the rule you suggested and am getting an error (replaced https with URL of app domain):
Error rendering smart-values when executing this rule:
Failed to get value for issue.description.split("[https://app.intercom").size: {{#=}}{{issue.description.split("[https://app.intercom").size}}-1{{/}}
I believe I've done it properly?..
Also tried without a bracket and "https://" part and looks like it parses properly with it, but number is 2x as high (I believe because of doubled text and URL for text). Dividing it by 2 kinda work, but how do I modify the rule so it won't break for "[https://app.intercom" line?
Short version is that you may need to experiment a bit with this...
There are reserved characters that the split() does not like, but I have been unable to find documentation for the valid/invalid list. Perhaps they can be escaped, but I have not had success with that method. That is why I only searched on "https" in my example.
One such reserved character is the period (.), and so when I need to split on that, I first perform a substitution and then split:
{{#=}}{{issue.description.replace(".", "ZZZ").split("ZZZ").size}}-1{{/}}
Perhaps you could perform some replacement of troublesome characters and then split using this method.
Register now
