Include subtasks in JQL query for Slack integration
Austin Lo
May 25, 2020
Hi all--
Trying to set up slack integration--
Want to send all updates for issues labeled "foo" , but also include updates on subtasks where the parent Story is labeled "foo"-- doesnt really matter how it behaves if the subtask itself has a label.
In the query, I can put in "labels = foo" to get all the issues labeled "foo"--but what I really want is something like "labels = foo OR parentIn (labels=foo)
Is there a way to do this?
Jack Nolddor _Sweet Bananas_
Hi Austin_Lo,
Sadly you cannot achieve the desired search using standard features on Jira, you must go for a third-party app instead. Using i.e. JQL Booster Pack you can type the following:
1) Query for issues having a given label and their subtasks
labels = foo OR issue IN subtasksOf(' labels = foo ')
(*) Note that this is just an example, you must tune above query to fit your needs.
Using this app you can also query other issues relations, check:
References:
Luiz Silva
May 26, 2020
FWIW it does not work with Jira Cloud.
Like • Jack Nolddor _Sweet Bananas_ likes this
You're right, my mistake.
I didn't notice the user was on Cloud T__T
Luiz Silva
May 26, 2020
Hi!
Unfortunately, such JQL (accessing parent or child attributes) is not supported in Jira Cloud.
An alternative solution could be achieved using Jira automation. You could, for instance, create a rule that labels child issues according to the parent. There's a blog post explaining this idea in more details here
Hope that helps.
Cheers!
Help us plant more trees
