We have Jira Cloud Standard with which we get 1500 Jira automations month. But due to a faulty integration, it has consumed most of our quota and we are just left with 30 for the 6 days which may be less for the optimum functionality.
Can I get them increased by 50-100 for this month only or even purchase them so that we are not stuck ?
Hi @Gursimran Singh , unfortunately there is no à la cart purchasing of automations. My best advice would be look to disable certain rules that are not critical to get you by through the end of the month. The other thing I would highly recommend is to closely look at all of your rules and where possible remove your global rules and make them project specific since that is unlimited.
Of course you could always reach out to Atlassian support directly and see if there was anything that they could do. But I have never heard of any such relief.
@Jack Thanks for your suggestion. I guess they should have a wayout. I dropped them a ticket but they are generally very slow to respond. Will update here what they have to say.
