Hola, necesito incluir en una issue un Sprint ya cerrado pero solo me aparecen los Sprints activos.
No es posible incluir un Sprint ya cerrado?
Hola @Ester Cerveró ,
No es posible seleccionar un Sprint cerrado en el campo Sprint. Puede asignar problemas solo a Sprints abiertos y planificados. Tendrías que reabrir el Sprint Cerrado. Entonces podrías agregarle un problema. Entonces podrías cerrar el sprint de nuevo. Sin embargo, eso cambiará la Fecha de finalización del Sprint para ese Sprint.
It is not possible to select a Closed Sprint in the Sprint field. You can assign issues only to Open and Planned Sprints. You would have to reopen the Closed Sprint. Then you could add an issue to it. Then you could close the sprint again. However, that will change the Sprint Completion Date for that sprint.
Indicate a closed Sprint in an issueHello, I need to include a closed Sprint in an issue but only active Sprints appear.
Is it not possible to include a Sprint already closed?
Register today
