×I have an infinite loop in my code at the level of lines 125 and 133. More specifically, these are lines
ComponentAccessor.getIssueService().transition(mycurrentUser, myresult2)
and line
IssueService.TransitionValidationResult myresult = ComponentAccessor.getIssueService().validateTransition(mycurrentUser, issue.getId(), transitionToBeDoneInt, inputParameters);
Here is my full code below. Anyone knows what is causing this infinite loop? I have looked at my code many times and I really don't understand what's wrong. I am using Jira and scriptrunner for a postfunction which is supposed to add a new comment.
this code has nothing recursive in it. It is simply supposed to do a transition and that's it, NO RECURSION. The error is so weird because I am having an infinite loop even though the code is not presenting any signs of recursion.
My code is very simple, it only needs to execute 1 transition and write a comment, no recursion and no loops are required in my code.
import com.opensymphony.workflow.WorkflowContext
import com.atlassian.jira.issue.Issue;
import java.util.List;
import org.apache.log4j.Logger;
import com.atlassian.jira.issue.ModifiedValue;
import com.atlassian.jira.issue.fields.CustomField;
import org.ofbiz.core.entity.GenericDelegator;
import com.atlassian.jira.issue.changehistory.ChangeHistoryManager;
import com.atlassian.jira.issue.history.ChangeItemBean;
import com.atlassian.jira.issue.comments.Comment
import com.atlassian.jira.workflow.JiraWorkflow
import com.atlassian.jira.workflow.WorkflowManager
import com.atlassian.jira.issue.changehistory.ChangeHistoryItem
import com.onresolve.scriptrunner.runner.util.UserMessageUtil
import com.atlassian.jira.config.SubTaskManager
import com.atlassian.jira.issue.link.LinkCollectionImpl;
import com.atlassian.jira.issue.link.IssueLink;
import com.atlassian.crowd.embedded.api.User;
import com.atlassian.jira.issue.comments.CommentManager;
import com.atlassian.jira.issue.link.IssueLinkManager;
import com.atlassian.jira.user.ApplicationUser;
import com.atlassian.jira.util.ErrorCollection;
import com.atlassian.jira.util.JiraUtils;
import com.atlassian.jira.workflow.JiraWorkflow;
import com.atlassian.jira.workflow.WorkflowManager;
import com.atlassian.jira.workflow.WorkflowTransitionUtil;
import com.atlassian.jira.workflow.WorkflowTransitionUtilImpl;
import com.atlassian.jira.workflow.function.issue.AbstractJiraFunctionProvider;
import com.opensymphony.module.propertyset.PropertySet;
import com.opensymphony.workflow.WorkflowException;
import com.opensymphony.workflow.loader.StepDescriptor;
import com.opensymphony.workflow.spi.SimpleStep;
import com.atlassian.jira.config.ConstantsManager
import com.atlassian.jira.workflow.ImmutableWorkflowDescriptor
import com.atlassian.jira.web.action.admin.workflow.ViewWorkflowStep
import com.opensymphony.workflow.loader.ActionDescriptor
import com.atlassian.jira.issue.IssueInputParametersImpl
import com.atlassian.jira.bc.issue.IssueService.IssueValidationResult
import com.atlassian.jira.workflow.WorkflowTransitionUtilFactory
import com.atlassian.jira.workflow.TransitionOptions
import com.atlassian.jira.bc.issue.IssueService.TransitionValidationResult
def log = Logger.getLogger("atlassian-jira.log")
log.warn("This is the last action ")
WorkflowManager workflowManager = ComponentAccessor.getWorkflowManager();
JiraWorkflow workflow = workflowManager.getWorkflow(issue);
def wfd = workflow.getDescriptor()
def actionName = wfd.getAction(transientVars["actionId"] as int).getName();
//Get worklflowname By actionId
int transitionToBeDone = transientVars["actionId"] as int;
log.warn("CAM 1 "+ transitionToBeDone)
ApplicationUser mycurrentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
log.warn("CAM 2")
log.warn("CAM 3")
int transitionToBeDoneInt = transitionToBeDone as Integer
List currentSteps = (ArrayList)transientVars.get("currentSteps");
log.warn("CAM 4 "+currentSteps)
SimpleStep simpleStep = currentSteps.get(0);
log.warn("CAM 5 "+simpleStep)
int beforeStepId = simpleStep.getStepId();
log.warn("CAM 6 "+beforeStepId)
ActionDescriptor ad = workflow.getDescriptor().getAction(transitionToBeDoneInt);
int afterStep = ad.getUnconditionalResult().getStep();
log.warn(" cam 7 "+afterStep)
log.warn( "resolved transition target last "+ComponentAccessor.workflowManager.getNextStatusIdForAction(issue , transientVars['actionId'] as int) )
targetStatus=ComponentAccessor.workflowManager.getNextStatusIdForAction(issue ,transitionToBeDoneInt)
log.warn(" cam 8")
def constantsManager = ComponentAccessor.getConstantsManager()
log.warn(" cam 9")
def statusName=constantsManager.getStatus(targetStatus).getName();
log.warn(" cam 10")
log.warn("cam transition target "+targetStatus + "status name "+statusName)
log.warn("CAM 11")
log.warn("cam 12")
log.warn("cam 13")
def mounaComment= "+++ added via workflow action "+"\""+actionName+"\"+++"
log.warn("cam 12"+mounaComment)
String content = (transientVars["comment"] +"\n"+mounaComment ) as String
log.warn("cam 13"+ content)
transientVars["comment"]= content
//inputParameters.setComment(content)
log.warn("cam 14"+ content)
log.warn("CAM 15 "+ issue.getKey())
def inputParameters = ComponentAccessor.getIssueService().newIssueInputParameters();
log.warn("CAM 16 "+ mycurrentUser+" "+issue.getId()+" "+ transitionToBeDoneInt+" "+inputParameters)
def myresult2= myresult;
log.warn("CAM 16 "+ issue.getKey())
try {
if(myresult2.isValid()) {
log.warn("CAM 17 "+mycurrentUser+" ")
} catch(Exception e) {
log.warn("CAM 18 "+e)
log.warn (result.getErrorCollection().getErrors());
Here is a snippet of what is printed in my error log
It is not your code, it is what you are trying to do with it.
As we said last week on https://community.atlassian.com/t5/Jira-Software-questions/Status-is-not-updated-after-performing-transitionResult/qaq-p/2106529 do not transition an issue in a post function.
The recursion is happening because the code you are running is run inside a transitition and because it triggers the same transition, it runs it again, to trigger the same tansition which runs it again to ....
You really need to stop trying to do this. Use the fast-track transition function in Scriptrunner, or do it as a listener.
I am trying to follow your advice and use a listener instead but I need to retrieve the transition name to only fire the event if the transition is called "MounaTransition". It seems that the following code is not working to get the transition name in the listener.
def workflow = ComponentAccessor.getWorkflowManager().getWorkflow(issue)
Here is the code I have written so far in my listener to try to do the same thing that I was doing with the custom post function before. Any idea on how to get the transition name/ID? I can only operate and execute my script if the tranition name matches the one I am interested in.
import org.ofbiz.core.entity.GenericValue
import com.atlassian.event.Event
import com.atlassian.jira.event.issue.AbstractIssueEventListener;
import com.atlassian.jira.event.issue.IssueEvent;
Issue issue = event.getIssue();
log.warn("CAM 0 ")
log.warn("CAM 0.1 ")
GenericValue changeLog = event.getChangeLog();
log.warn("HERE 1")
List<GenericValue> changeItems = ComponentAccessor.getChangeHistoryManager().getAllChangeItems(issue)
// changeItems = changeLog.internalDelegator.findByAnd("ChangeItem", fields);
//changeItems = changeLog
log.warn("HERE 5::: "+ changeItems)
log.warn("MOUNA IS HERE AFTER HERE 5 " +changeItems.size());
log.warn("VALUES 1");
int lastIndex= changeItems.size()-1;
log.warn("CAM 0.2")
ChangeHistoryItem value= changeItems.get(lastIndex) as ChangeHistoryItem;
log.warn("GENERIC VALUE "+ transientVars["actionId"] +" ");
log.warn("GENERIC VALUE "+ actionName +" ");
This is the wrong way to do this.
Listeners listen for events, and with scripted listeners, you can choose which events you want to listen for.
Instead of trying to work out what transition has been run and match it to a name (that could change), use the event system.
Create a custom event (Admin -> Issues -> Events)
Edit the workflow, finding the transition(s) you want to run this code for, and look at the post-functions for the transition. Change the one that says "fire event:" so that it fires your custom event.
Now your listener will run when you need it to.
(I'd also strongly recommend looking at the fast-track transitions, they'll need even less coding to use)
I have created an event, but how can I specify the associated workflows for it like shown in the picture below. I don't know how to specify the wlorkflows. Also, in my event listener code, how can I access the transition name? transientVars["actionId"] is not working, what's the workaround for this?
I think you've misunderstood this. The whole point of the event is that you don't need to look at the transition. If that event is fired, you know it's come from the chosen transition(s)
yes but I need to print a comment and I would like to retrieve the transition that was applied automatically.
Also, I need to execute the transition myself through this code so I need to retrieve the ID of the transition and execute it for the 2 code snippets I have just pasted.
You don't need to re-read the transition to make a comment.
You already know what transition was triggered - the one that fired your custom event.
I have tried the following code. It is using workflowTransitionUtil.setAction, workflowTransitionUtil.validate and workflowTransitionUtil.progress and it also fails. I am getting the errror:
Caused by: org.ofbiz.core.entity.GenericTransactionException: Commit failed, rollback previously requested by nested transaction.
com.atlassian.jira.transaction.TransactionRuntimeException: org.ofbiz.core.entity.GenericTransactionException: Commit failed, rollback previously requested by nested transaction.
2022-08-17 11:31:55,313+0200 https-openssl-nio-443-exec-533 ERROR mouh 691x78439x26 1a2i7f4 10.248.140.0 /secure/CommentAssignIssue.jspa [c.a.jira.transaction.TransactionSupportImpl] Unable to commit transaction : Commit failed, rollback previously requested by nested transaction.
Here is the code. I had hope it would work since it is operating in a different way than my old code. Could you please let me know about the solution that you mean and write down the code? I would like to execute the transition even though it is leading to itself.
log.warn("test")
log.warn("This is the last action done "+actionName)
log.warn("CAM 2")
int transitionToBeDoneInt = 1731 //ID of MounaTransition
log.warn("cam 3 " +transitionToBeDoneInt)
def myComment= "+++ added via workflow action "+actionName+"\"+++"
log.warn("cam 4 "+actionName)
def content =( transientVars["comment"] +"\n"+myComment )as String
log.warn("cam 5 "+ content)
log.warn("cam 6"+ content)
log.warn("CAM 7 "+ issue.getKey())
log.warn("CAM 8 "+ " "+issue.getId()+" "+ transitionToBeDoneInt+" "+inputParameters)
def workflowTransitionUtil = ( WorkflowTransitionUtil ) JiraUtils.loadComponent( WorkflowTransitionUtilImpl.class )
workflowTransitionUtil.setIssue(issue)
workflowTransitionUtil.setUserkey(mycurrentUser.getKey())
workflowTransitionUtil.setAction(transitionToBeDoneInt);//Id of the status you want to transition to
log.warn("CAM 9 "+ " "+issue.getId()+" "+ transitionToBeDoneInt+" "+inputParameters)
workflowTransitionUtil.validate()
log.warn("CAM 19 "+ " "+issue.getId()+" "+ transitionToBeDoneInt+" "+inputParameters)
workflowTransitionUtil.progress();
log.warn("CAM 11 "+ " "+issue.getId()+" "+ transitionToBeDoneInt+" "+inputParameters)
I'm not sure how else to explain this.
You can not run a transition inside itself.
So, you move to a listener, that's fine.
But you are still creating an infinite recursion.
You are trying to trigger the same transition, which will trigger the same transition, which will trigger the same transition... As these start to stack up, you'll find events are being fired faster than Jira can process them, so transitions start to be started while others are running, so you're getting recursive errors.
I strongly recommend that you do this:
1. Add a post-function to the transition that sets a (hidden if you want) field. Let's call it "I have run" and it could be of any type
2. Use a fast-track transition instead of trying to write your own. See https://docs.adaptavist.com/sr4js/latest/features/workflows/post-functions/built-in-post-functions/fast-track-transition-an-issue
3. In the conditions to execute in the fast-track, put in at least "only run if "I have run" is empty"
Why adding a post-function to the transition that sets a (hidden if you want) field. My original code is already running inside a postfunction. Why would I add a second one? Adding a second postfunction would not change the fact that I am transitioning from the same status to itself. So how would it solve the problem?
Yet again, you must not transition an issue during a transition.
You need the flag to be set the first time you run the transition, so that you can detect it and not run again. The transition has to finish before the flag will be set properly, the next execution of the transition has to be done after completion so the flag is there.
can you please write some code to let me know what to do? I am kind of lost. How can I stop the transition from executing with the flag?
Ok,
https://library.adaptavist.com/entity/change-the-value-of-a-custom-field-in-a-post-function gives you "how to change a custom field in a post-function"
Then, when you configure your fast-track transition, you can read the field in the conditions for it (see https://docs.adaptavist.com/sr4js/latest/features/workflows/post-functions/built-in-post-functions/fast-track-transition-an-issue )
It will sill transition to itself, isn't that a problem?
Yes.
That is what I've been saying throughout - the whole problem is that it will transition to itself.
Trying to recursively call a transition is the problem. You need a way to break out of that recursion.
I'm not sure if I got your full use case, but maybe I can ask some questions or give you pointers to help you.
In the script, you perform a transition - will this trigger the same postfunction to be called? If yes, make sure that you properly exclude this post function (by removing it from the transition or specifying a corresponding if condition.
Alternatively, I wonder why you're using Scriptrunner and if not Jira Automation could be a simpler solution for you.
Matthias.
No this code has nothing recursive in it. It is simply supposed to do a transition and that's it, NO RECURSION. The error is so weird because I am having an infinite loop even though the code is not presenting any signs of recursion.
